Is anyone using an AI related workflow that generates an outline of an article AND THEN generates the content for each outline?
As the title says, I’m trying to figure out how to build a workflow with either an OpenAI API connector, or Anthropic API connector, that firsts generates an outline of an article - displays the results - then generates the content in each of the outlines.
I’m sure it’s technically possible, but I’m not sure where to start with it. If anyone is doing it, or has done it, and would be willing to give some pointers, I’d be more than grateful. Thank you!
This is what you would call an “agent” or a “worker” (a series of tasks that are completed and pushed through various stages to provide a definitive answer or response).
You can create your own worker or agents via Workflows or you can have it made through the Assistant API.
As far as doing it, you’ll need to do some research on Bubble and API Connectors itself to get more knowledgeable in this field.
