Is fuzzy search actually works on safari and edge?
Im using the fuzzy search plugin, and i just realized when im using edge. It stopped working it gives error “Fuse is note= defined” is there any solution so it can work on safari and edge before I change all my searching feature on all page T_T
It should work. Check Plugin Docs.
