Is it possible to align a focus group to the right side of an element or page?
In the top right corner of my product’s dashboard is a pretty standard component - a user’s name and profile image and clicking this has a dropdown. The problem is that this element doesn’t have a fixed width since the width is determined by the name.
I’d like to have a focus group in that corner but I’m finding that the group will appear off the page if the name is too short. I want the right sides of the two components to be aligned but it doesn’t seem like that’s possible?
Any advice?
put a floating group on the page, then make the reletive referance of the group focus to the floating group, then you can possition it where you want it :slight_smile:
