Issue : Creating reusable element
Hello,
I tried to create a reusable element from a group but it doesn’t work. The button inside the group is not taken into consideration when creating the reusable element.
I made a video that you can check here :
Did I miss something ?
Kinds regards,
You didn’t miss anything:
Thanks for the information :slight_smile:
I hope it will be fixed soon.
I have the same issue. What I did was manually create a reusable element from the drop-down box in the top left of the design page and then paste in the group that had the elements that I needed and adjusted the size. That seemed to work for me.
Ok John, I will do that, thanks !
