I’m using the 1T - Input Watcher plugin to trigger an event when the user presses Shift + Enter in an input field. The event works perfectly and sends the data as intended.
However, I’m running into an issue when trying to reset the input field afterward. I’ve tried:
- Clear relevant inputs: Does not work.
- Reset group data: Does not work either.
If I trigger the workflow by clicking a button directly, the input resets correctly.
Has anyone experienced this issue with the Input Watcher plugin? How can I reset the input after the event triggers?
Thanks in advance for any help!
