Issue when applying a style on a slider
Hello,
I am facing an issue when trying to change the color of an input slider. I used the “NFT Marketplace” template to build my project. I try to change the color of the slider from blue to pink, but i cannot see how this style was set. after a few days of research i decided to create a new commun slider style an apply it to this slider.
The new color is applied only on the line and the old style is always present ( see enclosed pictures).
Any idea about the source cause of this issue.
Thanks in advance for your help,
Yamilyana
Are there conditionals added to this element or its style? if yes, remove or edit them.
Is there an ID added to it? if yes, remove it.
