Hi, I use a lot of audio files (mp3) played in a plugin AudioCustomPlayer.
What’s happening?
Recently, in iPhones, the audio files are not being downloaded and cached as fast as the audio playing. So it usually stops in the middle of the audio. (the audio usually varies between 1 and 8 seconds)
This issue is not happening in Android. (but it happened too when AWS changed their protocol some weeks ago)
Do you also have this issue???
Do you know what it can be???
Have you contact bubble about it???
Do you know any solutions???
I’m really desperate because with this issue, my business breaks to the ground, and my app gets useless!!
