It ’s a very difficult problem
I want to send comments with 10 likes or more in a slide show However, since comments are mainly text, I can not send comments in a slide show, but there is a way to take screenshots with comments with 10 likes or more, or it is different Is there a way to show it in a slideshow?
There’s gotta be an API out there that puts words onto an image, no? Have you looked at that angle?
I think that idea is good, but do you know how to do it?
Check out https://www.bannerbear.com not sure if it helps, but you get API access
Depending on how many you need per month - https://htmlcsstoimage.com/ can be a great solution as well, and don’t worry it’s not a difficult problem, you will overcome it for sure :slight_smile:
I’m sorry I’m ignorant,
You just have to connect this with zapier, right?
I just
