Josh and I are going live on June 3 with product demos and Q&A
wdym?
Man, I’ve been using the app connector trick with 100 results max, now with this I can do more things in a very simple way. Thanks!!
I said … i am very dumb please totally ignore me :face_with_peeking_eye::face_in_clouds:
@emmanuel are global expressions secure or can be seen publicly like option sets ?
Yes, all global expressions can be seen by all users (i.e the logic that defines them). Any data you fetch within them of course observes privacy rules. So, don’t statically define secrets e.g API keys, AI system prompts you don’t want to be public, in global expressions.
Badly need a Private toggle for global expressions just like API call parameters
@rishabh2810ag / @georgecollier
Global expressions in their current iteration work this way, but the team is actively working on improving this so things will only load on the pages they need to and that sort of thing.
This isn’t the final version of global expressions
I assume ‘global expression folders’ are on that future iteration list? They’re gonna be used a lot.
Correct
In case it helps anyone, Buildprint will automatically the best identify global expression candidates in your app and implement them for you :slight_smile:
just created a new thread to centralize all comments and thoughts on the latest features,
stop by
