Hi…
Please somebody aware for the problem kindly guide to make the keypad not overlap the input in pop-up > IT LOOKS VERY UN-PROFFESIONAL @romanmg @jarrad @NigelG @louis.j.briggs
Hi…
Can you share an image of what you’re seeing? I’m not sure what you’re asking about from your post, sorry. An image may help.
@potentialthings thank you for the concern
rnThe pop gets over lapped by the keypad and not dragble…
Hi @potentialthings
Did you get anything regarding the issue.
It really makes the webapp looks… Pitiful
Please help. should have been pre-equipped in bubble, I guess they should have coded in bubble app itself… Buhhh I can’t understand.
@emmanuel would you please suggest some code to make the input field auto move above the keypad… like in this messenger.
