Layout is not changing when I go from fixed to column and use the preset mobile. It still stays the same as default the color is the only thing working
Hello Wargestudios,
Are you trying to build an app or a web app, if you are looking to build an app i think you should change the width and length to the sizes in which you want, i have had experience with something like this before
