LikeShop.me Build - Instagram Post Grid with Assigned Links
I am trying to make something similar to https://likeshop.me/golfdigest where it shows an accounts posts in an image grid, with links assigned. Has anyone been able to do this with an API or a plugin?
It would be fairly simple to build with allowing the user to just upload the same image that was on Instagram and then assign a link, but I am looking for an automated solution. Any help is appreciated! Thanks
were you able to find a solution?
Thats not too difficult.
You have to use the instagram API together with the facebook graph API.
Then you can easily pull the feed of the connected user.
