Limitation with “Do a Search for” in Backend Workflows – Accessing Records Beyond a Certain Position
Hi everyone,
I’m encountering a limitation in backend workflows on Bubble, and I’m wondering if anyone else has experienced the same issue.
When I attempt to perform a search in the database using a “Do a Search for thing” action in a backend workflow, it seems that I’m unable to access records beyond a certain limit. For instance, if I try to search for records in positions 50,001 to 50,002, the system doesn’t allow it.
I’m curious about the exact impact of this limitation. Does this mean it’s impossible to access a record in a backend workflow if it exceeds a defined limit set by Bubble (e.g., the 64,054th record in the database)?
Any insights or documentation on this hard limitation would be greatly appreciated, as encountering this issue randomly is highly disruptive to our work.
Thanks in advance!
