Link element - Repeating group (row container)
Hi!
I need to create link elements inside a repeating group (because I need the option to open in new tab).
I used to hack this with ‘fixed container’ groups, placing a link element in there with the same widht and height.
But how can I do it with a row container that doesn’t allow to overlap elements?
Use an ‘align to parent’ container to keep it responsive…
i.e. inside the RG cell put an align to parent container (or you can set the RG itself to align to parent)
Then, inside that put your row container (with everything inside it), and also put the link element, with no max widths or heights to ensure it fills the full cell, even if the content changes the cell size.
