I am having an issue with linking 2 data types. The 1st data type is “Equipment” and the 2nd data type is “location”. Each “equipment” thin has a “location” thing associated with it.
The equipment data type currently has over 2000 things and most of them have a “location” thing associated. However, when I try to add a new or modify certain ones, I cannot add the location thing using the manual data entry. The location field that I am matching on is called the “Snap”
This is image is from the equipment data type where i type in the location Snap.
This is a location Snap that I am trying to use.
When I type this location Snap into the Equipment Location, it does not accept it. I am not sure what is going on. Again, this works on 1000s of records except for ~15. Not sure what is going on. Any ideas?
