Looking for bubble develop to refine work flow logic and data base design
Looking for Bubble developer to help refine clinical decision tool MVP. Focus on workflows, logic, and database structure. from each assessment the data needs to be stored in a database for processing and then output on a results page.
The processing will be done seperately.
Looking for a Bubble developer to help refine an MVP clinical app.
Main needs:
  • fix multi-step wizard (stable flow, save each step, step state)
    add multimedia to steps on the assessment wizard
  • clean database structure (one field per variable, structured data).
  • implement simple modular decision logic
  • build clean results page
Not a full build – refinement + structure only.
Must have experience with workflow-heavy Bubble apps.
Please share relevant examples and rate.
Welcome to bubble.io community
Please check your DM
Hey @raphaelolaiya1 :waving_hand:
Welcome to the bubble community! :tada:
Maybe it would be worth a chat to see if we might be a good fit?
Hi @raphaelolaiya1
I just sent you a detailed response to your dm which includes a link to my calendly slot that you can use to schedule a call with me + my linkedin profile where you can see previous recommendations that i have gotten from previous clients as well as links to my past projects built on bubble + an action plan on how i go about working on your project
Regards
Bolumole Tobi
looking forward to your response
