Hey all! Does anyone know how I could make the right side of this group (a vertical scrolling list of videos) the same height as the video player on the left dynamically?
Put a hidden group behind it and stretch it out both ways. Put the video player inside a similar group.
Then optionally group them together.
Thanks! But I’m not totally sure on your solution. Any more details/specifics on that?
Add Html element and set both of group’s of max-height to some value.And add “overflow: auto scroll” to the right-side group. if it is get more then, scroll bar will show and both group of height will set to same.
I’m not familiar with HTML is there anything I should just be pasting in there?
Here’s the video group again along with the right sidebar playlist showing the responsive issue:
Repeating groups collapse by default. By placing a group behind it, the main group won’t collapse.
@joe5 were you able to able to accomplish this? Looking to do something similar and can’t figure it out. Data source will only be YouTube.
*Edit: Nevermind! Figured it out.
Mind sharing how you did it? I gave it a shot but maybe our editor was more involved than others due to the design.
Hey @joe5,
Not perfect, and will probably tinker a bit more. But should work. Here’s a sandbox account:
