So I have an element visible on-screen that iterates thru data. With each iteration, a PDF gets generated. In order to generate the PDFs, the element must be visible on screen.
What I want to know is this: Is there a way to place a mask (a group or shape) over this visible element so the user does not actually see the element as it iterates through the data. The shape or group overlaying the element would simply display a progress bar of some sort.
You will approach it from the opposite though. Instead of giving the outer container ID (or group) to the Element(s) to capture property, you will assign IDs or class names to the inner elements that you want to be visible. Because, this field expects a list of IDs.
This is the furthest I can help since I can’t try a paid plugin
