I’m trying to implement Mielisearch. I’ve installed it on AWS and now I need to scrape my data. Mielisearch’s docs say that every data type needs to have a unique ID.
Do I create a field in each data type I want the search to include and just pop a string of characters in that field–the same string for each data type? If so, does every record need to be populated? Meaning, if I have a datatype with the fields Cake, Cookies, and Pies, does every line item in the database need to have the populated UID string? And then do I use the API to trigger the scrape?
