Multi dropdown does not show values
I have quite a few multi drop downs and they are all functioning well but there is one in which there are static choices with somewhat big names. While filling or updating, the options show and I am able to update the record no matter how many options I choose. But when I revisit the page, it shows only two choices. I created a new dropdown but it is happening even in that. I have not set any maximum limit so one choose as many options as he wants. Why is this happening? Has it anything to do with the long names in the options?
Are the names so long that they can’t fit into the display? Maybe an image of the display and your setup?
Kevin
Free no-code bootcamp by Airdev
Names are fitting in the display but still it does not work.
Thanks
Can you show a picture or link to a Loom with your setup?
Kevin
