My side moves side to side on mobile
Hi there,
my site moves from side to side when being viewed on a mobile device. I have looked at other sites that are built on bubble and this does not happen - namely, bubble.io. The site is locked in place.
What is the trick to achieve this?
Thanks
Frank
Responsive design so that the site and it’s contents fit onto the width of a mobile device. Sometimes, if everything is done properly for mobile responsiveness, there may be an element somewhere on the page that is not set properly for the width to decrease for mobile devices.
You likely can not use the debug mode to inspect while previewing, so you’d need to go into the editor and check all the elements width settings to isolate the one that is not decreasing as it should.
Wow - spot on buddy!
Thanks for that
fixed
Cheers
