How do I capture the returned token from an o-auth url callback?
In web we could simply get it from the url as a parameter. But on mobile, how do we do that?
If your using the Google plugin by bubble, the best way so far is using (signup/login via WebView) I’ve tried without WebView but after the user logs in on the browser, the redirect back to the app fails to login the user
Thanks! I want to use the Twitter o-auth not google. How are you getting data from a “url” in native?
i did mine in the webview, so you need a page on your web app that handles the login (a login button, for google twitter) when a user clicks the button and logis in bubble automatically redirects back to your app, in my case id say the google plugin handles that, im not too sure about twitter.
