Need help about layer
Hi all,
In my app, I just created a star shape above google map. Which I want is when cursor on star shape I can still click and drag the map behind it.
Thank you so much!
I personally don’t think that is possible. The star element is what the cursor will be hovering, so it will not be on the map and so the map will not be capable of being dragged.
I just figured out. CSS for the shape: pointer-events: none;
