Need help converting/inputting data to a PDF
Hello!
So I am working on a character creator app. I’ve finished the entire thing, just need to format it. What I need help with is one of the following:
-ideally: the inputs on the character creation steps will modify a PDF and at the end, provide a PDF with all the inputs there
-also acceptable: the site will create a PDF with all the answers, though this will be messy potentially
I have a fillable PDF draft already, so I think it should be easy, but I can’t figure out how to step by step make each input correspond with a fillable field in a PDF.
Thank you!!!
You can do it with the plugin PDF Filler Plugin | Bubble that enables your app to https://docspring.com/ API.
