I want to know if its possible to have random string chosen from a list of possible strings.
Like for instance names:
James
David
Carl
Max
OR
Boolean:
True
False
I don’t care too much about repeats :3
James
David
Carl
Max
OR
Boolean:
True
False
G’day. If you have a list of possible options saved in the DB or as option sets, then it is pretty easy to either do a search for the thing:random item or grab an option > all options:random item
Thank you Brett! I had the same issue and that solution worked for me
