Need help for search from data base
When setting restrictions on a recurring group in order to filter the data according to the date element, for example date=> and date <=, but the result is not expected. I have more than one entry in the database with the same date, but the result is only one entry.
Hi there, @sc.services.zamzam… if you can share some screenshots, I’m sure someone will be able to help you out. You could be running into an issue with privacy rules or it could be the fact that dates are dates and times, and the time element trips folks up a lot when trying to filter data. Without knowing a lot more about (and ideally being able to see) what you are trying to do, though, it really isn’t possible to help.
Best…
Mike
