[Need Help] How to redirect users to a URL
Hi, I have a form that users can submit information through, including the website of the product.
Once saved, users can go to the product’s page and should be able to click through to the website of the product, by way of a “get” button.
Except that it doesn’t work.
Website link is set to “text” in the data field, and no privacy rule set.
It doesn’t matter if the URL is the full one or if it starts with www.
It this because I am just testing, or am I doing something wrong?
‘Go To Page’ is only for internal pages (and you need to enter the page ‘name’, NOT the URL).
For your case, you need to use ‘Open an External Website’ instead (either that or use a Link Element).
Ah, thanks!
