Need help; I can’t hide small sidebar on my small breakpoint
I follow the course as student Flexcamp from Gregory John ( super nice course that i’m really reccomand) but know I would like to CHALLENGE me and pimp and have two behaviors with the sidebar
  1. When I switch from a large breakpoint to a small breakpoint, the behavior of the sidebar changes (“FG Brand sidebar (icon + text)” or “FG Brand Sidebar SM (icon)” + hidden in ‘Navbar’ burger menu)
  2. When I click on the collapse/expand button of my sidebar, it displays the “FG Brand sidebar (icon + text)” or “FG Brand Sidebar SM (icon)”
I would like to have both behaviors in responsive.
My problem is: I can’t hide my “FG Brand Sidebar SM (icon)” on my small breakpoint and I don’t have any idea if my logic and process is correct or to complicated.
Can you help me please, check point 9 and 10 bellow in the A) The Design to view the problem. :face_holding_back_tears: and follow my B) Process below
Thank you :pray: :blush:
A ) The Design
  1. Default page, sidebar is open as default
  1. When I switch de viewport to another breakpoint
  1. When I switch de viewport to a medium breakpoint, sidebar is smaller
  1. When i switch de viewport to a small breakpoint, sidebar is hide
  1. When i swith de viewport to a smaller breakpoint, sidebar is hide
When i click on the button sidebar and drag the viewport to another breakpoint
  1. When I click on the button sidebar, then the sidebar is smaller
  1. When I switch the viewpoort to a medium breakpoint, sidebar is smaller
Alert! How to hide the sidebar in small and smaller breakpoints?
  1. When i switch de viewport to a small breakpoint, sidebar is NOT hide !
  1. When i switch de viewport to a smaller breakpoint, sidebar is NOT hide !
B) Here my process.
I don’t know if I did things right or if it’s too complex and could be simplified.
  1. I create a button “FG Collapse Brand Sidebar” and put on my “FG Brand Side Bar”. Click
  1. Conditional FG Brand Side Bar
  1. Click FG Navbar + Conditional FG Navbar
  1. Click Group Home + Conditional Group Home
  1. Click “FG Brand Sidebar SM” + Conditional
  1. I put this button floating group “FG Expand Brand Sidebar” on my “FG Brand Side Bar SM”
  1. Click here.
  1. I add a custom state to show or hide the sidebar when I click on the “FG Expand Brand Sidebar” or “FG Collapse Brand Sidebar”
  1. Workflow “FG Expand Brand Sidebar is clicked”
  1. Workflow Click “Set states sidebar visible?.. of dashboard-m”
  1. Workflow Click “G Collapse Brand Sidebar is clicked”
have you reached out to the course creator?
If you added a button I assume you used a workflow to hide it, which means you need a workflow to show it. I would imagine the creator of the course likely taught it to use conditions on the elements to make them visible or not.
I did not
Just follow the way the course creator explained it, which again I assume is to use conditionals, and the reason why I assume the use of conditionals is because that is the best approach and other methods are not as optimal so no need to try something different there.
But either way, I already provided you the solution which is
So, setup the workflow action to use the show element workflow action, or setup conditionals as likely the course creator expressed.
