Need help in login workflow
Hello everyone,
I need help in log the user in 2 step authentication . I want to make a feature in which when user click to the login button in login popup the user will get a login code email and then 2 step authentication popup will show to the user.
So the user will enter the code for login into the app.
This is exactly what you’re looking for
