Need Help in SlideBar Menu Plugin
I tried to generate dynamic data’s slide bar menu option from my database call categories as shown in picture.
image link : http://imgur.com/3B2zQAA
But when i Preview. The slide bar is not vertically shown by each option. How do i add (line break)
in dynamic data? Any help will be appreciated.
image link: http://imgur.com/xtAdyjU
Hello :slight_smile: I think you’d need to do a dynamic expression (showing one item), press enter, dynamic expression showing one item, press enter (etc). Otherwise it may just be easier to manually enter the words (instead of using a dynamic expression) if there aren’t that many different options.
Thanks for your fast respond:slight_smile: . For now I show them staticly like you said, Thanks.
No problem :slight_smile:
Hi all,
Is there still no solution to insert a line break ?
Thank’s
Hi @georges.dru :slight_smile: That should work by formatting the expression in this way:
Thank’s a lot.
Each time I marvel at the simplicity of the solutions that can be found with bubble.
This is awesome. I was able to quickly and easily add a slider menu. I have a variety of user types and created a data type called “Menu” and I “Do a search for” to show a custom list of options based on user type. Adding the line_break was a great way to show a clean well-formatted list of choices.
Is there a way to add a logo on the top of the slide-out panel? Or for that matter, any other non-clickable items?
Thank you all for sharing your knowledge.
