Need help intergrating two API
Basically, I need to combine two functions from two different APIs from the same provider.
My web app needs the search function from this API:
https://api.spoonacular.com/recipes/findByIngredients
And the information provided by this API:
https://api.spoonacular.com/recipes/complexSearch
I contacted the provider says this function will be able in maybe around 3 months. That’s is way too long. I hope we can find a solution until then.
I have tried personally but I couldn’t find the solution. I know it can be done with some workaround. Are you interested in this job let me know and we will go over the specifics of what I exactly want.
Kind regards,
Konrad Nietopiel.
Sent you a PM :wink:
Hi @conradaszen ,
I would like assist you sent you a PM please have look.
Regards
Kevin
Hi Konrad,
What you are wanting done is right up my alley of expertise and I would be happy in helping you out on this.
You can reach me on andrewjohnson56782@gmail.com
Best Wishes,
Andrew
