Need help optimising page
Hi everyone,
I am building a dashboard which is basically all charts - relatively simple ones.
My backend is in Firebase and I am using the API connector to fetch data.
I’m on a paid plan and finding the time to load charts / refresh page painfully slow.
I’m wondering if I’m doing something wrong. Is there a way I could be optimizing this?
Righ tnow, each chart has its X axis and Y axis linked through an API. Its as vanialla as scenarios come.
Help would be appreciated!
PL
How slow are you talking about?
It varies from 1 second to 30 seconds.
Its really inconsistent
I’m not sure if I should be using a group / container of some sort and calling the API to that then having charts inside the group / container that reference the data…
or
whether I should be keeping the charts having direct links to the APIs
