Hi folks,
I have a problem with some un wanted padding that I can’t figure out how to remove. Any thoughts on what I should look at?
Hi folks,
I’m not sure what you mean by that? I was attempting to design it responsively but I’m not sure what settings I should look at?
Thanks, the emojis were really put in there by @ideable. I used their template.
I’m not sure where I should look to check that? I have the page open in a browser where I open dev tools and resize the page to test it’s responsiveness out.
Turns out I had a recursive error in my app keeping me from seeing any changes I made to try to fix this issue. Once I fixed the recursion I am now able to troubleshoot.
