Need help seeing if this is User's first post
Hey Bubble! Another day, another question :smile: So my question is, how do I see if this is the User’ s first post? I want the User to get a “Badge” when they post for the first time, how do I check in a workflow if this is the User’s first post? Thanks!
Hi @nickkessel22
Basically you need to define a field in the user type of type “Post” (first define this Post type) and make it a list (checkbox “list”) in which you add an element every time this user posts something.
To check if a post is the user’s first post you could use the condition “User’s Posts count = 1” if the action happens just after adding the post to the User field.
Best,
Arthur
Thanks! Works like a charm.
