I have created an HTML box which contains HTML and Javascript code using the tag to generate a map using an API, but in this code is my token, does anyone know how I could hide this token and that it can be used in the box? I have tried many ways but either I can’t use the token or when I manage to use it anyway the user could see the token when inspecting the page.
You have to use the API connector plugin and put the token there
