Need help with button and link options
Hello Community,
I have a problem and want to find out if it can be solved. I have a button that opens a pop-up when I click on it (on the same page). But now the context menu of the link should appear with a right click on it. Why? This link would redirect to the dashboard and open the desired pop-up there.
Is this possible? Since I’ve been trying to solve the problem for a few hours now.
Jens
When you say “But now the context menu of the link should appear with a right click on it. Why? This link would redirect to the dashboard and open the desired pop-up there”
That bit is confusing me? Can you explain in little more detail or perhaps create some example?
