Need help with format
Hello,
I need help with formatting a query.
see screenshot below
gives me the result
" username1 , username2, username3"
How can I format it to have
“username1” , “username2”, “username3”
quotes are not un the correct place
Thanks a lot for your help.
Use ‘Format as text’ on the list returned from the search.
Thanks for the response.
I tried this
But now the query looks like this
Capture2
The objective if to have
“usernames”: [
“humansofny”, “6pri1”, “molas.frederic”, “selenagomez”
Many thanks
You don’t want to do another search for Users inside the content to show… rather you want to refer to the thing from the list your formatting i.e. This User (or This Text, if it’s a list of texts)…
So just do a search for Users: format as text.
Then use “This User’s Instagram Link” with a comma delimiter.
Thanks a lot for your help, I used “This text” and now its working as expected.
:raised_hands::pray:
