Need help with JSON body dynamic values
trying to figure out how to properly input the dynamic values content parameter ( “content”: “<InputCode’s value>”) when i run it it returns a null value.
You enter it in the Workflow or DataSource where the API call is made.
Please elaborate.. Complete newbie at this
How/where are you using the API call?
Change “InputCode’s value” to “InputCode”, the apostrophe is breaking the JSON.
Remove the apostrophe on “inputcode’s value” and make sure the private checkbox is unchecked.
On the workflow, you enter the Datasource
