Need help with popup
How to do keep popup from disappearing when clicking the page?
Hi there, @syedhmd… if you mean you don’t want the user to be able to dismiss the popup by pressing ESC or by clicking away from the popup, check the This popup can’t be closed by pressing ‘Esc’ box on the popup element’s Appearance tab.
Hope this helps.
Best…
Mike
Thanks Mike…that works! :slight_smile:
However, it’s position is also fixed on the screen. It cannot be dragged on the screen. Can you also help with that?
