Need help with setting up custom domain
Hello everyone!
I was setting up a custom domain for my app as socios.sumup.pe, but I want to make able to the user to enter to the website by typping www.socios.sumup.peas well.
But when I’m trying to setup the domain, bubble doesn’t provide me any type, name or value to add to my domain manager, which is weird because on your tutorial video it shows parameters for both
So, I decided to made a CNAME record from www.socios.sumup.pe that points to socios.sumup.pe . But the later is an A record, so it’s weird that that check fails. The docs actually show screenshots of using CNAMES for www , but then tells you to use A records. Do you specifically check for A records?
Also, I have this guess. The typical use-case is probably for company.com , not xyz.company.com. So, can bubble handle www.xyz.company.com?
I hope you can help me with this. Thanks in advance!
