I’m doing a spotify API Get, which returns “Spotify:Artist:(id needed)”
How do I trim the “Spotify:Artist:”, leaving me with just the (id needed), when writing to the database. Please help.
Thank you
Thank you
Hey @joshsgalbreath
Try find and replace “Spotify:Artist: with an empty field. Probably need two find and replaces. Find and replace “ with an empty field as well. It’s either that or use regex i think.
Would that work?
This seemed todo the trick. Thank you!
Awesome, glad it helped!
