NEED little HELP with my project
HI !
A have a input frorm for clients in front page , with adress , name mm with custom work categories with checkbox sign up as user.
Then a have company´s with registration as company… with adress and custom categories the work with…
So a have built a dachboard for companys, and one for customers… with “repeating groups”
To the problem … when the client sign up with custom categories mm … How to notify the company that has the same categories ex… With mail exempel… ? trigger action from a repeating group when a new row example
Tanks fror help
Hi @tradspecialisterna
You can send an email to the company or a notification to be saved in db when the user signs up.
Thanks
A wish it was that easy :slight_smile:
Tanks
If you would like me to look into it, Book a call with me
Thanks, Ali - Finding solutions to your SaaS & SME problems
Connect with me on Linkedin: https://www.linkedin.com/in/a-imran/
Or book a call to say hi: Calendly - Ali Imran
No one-…
Tjena!
What you need to have a look at is the concept of “Database triggers”, which let’s you monitor changes to a database entry, and inside it, take some action based on set conditions.
Here are some resources on this concept:
Feel free to PM me (Swedish OK) if you need more help!
