I’m trying to build a plugin that uses the Boxicons library. I’m not an expert, so I really have no idea what I’m doing. Any help is appreciated.
Here’s what I have so far. Taken most from the nice Feather Icons plugin - trying to use that as a reference.
Initialize:
function(instance, context) {
// Generate random string for div element ID
var divId = "id_" + (Math.random() * Math.pow(2,54)).toString(18);
// Create our div (a.k.a. wrapper) for the icon (which will be created in the 'update' function below)
var div = document.createElement("div");
div['id'] = divId;
div['style'] = 'width:100%;height:100%;';
// Add the new div to the Bubble instance
// Store the div ID to the Bubble instance so that we can locate it in the 'update' function
instance.canvas.append(div);
instance.data.divId = divId;
Update:
function(instance, properties, context) {
// Define properties
var width = properties.bubble.width;
var height = properties.bubble.height;
var type = properties.type;
var name = properties.name;
var color = properties.color;
var size = properties.size;
var rotate = properties.rotate;
var flip = properties.flip;
var border = properties.border;
var animation = properties.animation;
var pull = properties.pull;
// Find our original div
var divId = instance.data.divId;
var div = instance.canvas.find('#' + divId)[0];
attributes = {}
attributes['height'] = height;
attributes['width'] = width;
attributes['color'] = color;
attributes['size'] = size;
attributes['rotate'] = rotate;
attributes['flip'] = flip;
attributes['animation'] = animation;
attributes['pull'] = pull;
attributes['type'] = type;
attributes['border'] = border;
var iconName = [name];
div.innerHTML = iconName;
Preview:
function(instance, properties) {
//document.appendChild(div);
attributes = {}
var previewImg = document.createElement("img");
previewImg['src'] = '//dd7tel2830j4w.cloudfront.net/f1606865125426x258090400456897570/2020-12-01%2015_24_19-.svg';
previewImg['style'] = 'width:100%;height:100%;opacity:0.4;';
div.appendChild(previewImg);
Initialize State:
return name;
It sees the name, but no icon… and no errors in the debug
