Newbie, needing help with lookup using a selected value in dropdown
I am trying to get a lookup value in a table using a selected value in a dropdown field as the criteria. However, 's value is not working. Any help is appreciated.
Please pick a subcategory to help organize the information. Thanks!
Also, the more context you provide with your questions (screenshots, link to an open app, etc.), the more likely you’ll get good help quickly :slight_smile:
Hi @som.chilukuri,
Can you show us a screenshot of what’s not working and I’ll try and help. I’m not quite understanding what you mean.
Paul
9 hole score is a dropdown field and based on the selected value, I need to search a corresponding quota in a lookup table
