Newbie problems
Hi everyone. I’m a newbie and the first problem I’m encountering is a perticuler text element is not aligning with other element when I preview it. Even tho I’ve used the assisted vertical line to make sure it’s placed in the right place. THANK YOU
Put them under a group … or select them both, right click and choose “group elements in a group”. Set the group to fixed width.
Caveat: this is a patch solution as it has implications of what else is on the page. As you build your app … the entire approach of how you take on building its structure will have an impact on how elements behave.
Thank you, I will try this
