Oh. I like this a lot, and am using it already !
Some feedback…signup is a bit odd in that you can still signup when you don’t fulfil the password criteria and it throws an error.
Hi Nigel, Thanks for the kind words and the feedback.
Can you tell something more about the actions you have taken to cause the error?
Actually I think it was just Bubble being slow.
Hi All!
We are a few weeks in and I wanted to highlight the prize for the most innovative, well designed app built for #nocodevember.
First, the winner will get 1 Month Free on for any Bubble app.* Also, you’ll be the first to get the exclusive and brand new Bubble merch I have coming in. I will personally make sure you’ll be getting it even before members of the Bubble team! Lastly, as we ramp up our external communications, we’ll be sure to feature you and your work across the entire community!
So keep building, keep sharing, and as always if there is anything I or the Bubble team can do to help, just reach out.
I’m looking forward to your builds!
Erik
*Everything but Dedicated plans, but you probably figured that anyhow.
Hi Gaby
I need to build a sheduling tool which takes into account timezone.
I was wondering if you have any tutorials showing how you built this timezone application?
thanks!
Check her youtube channel, you might find something there.
