Not sure reapiting group issue
Hi everyone, I am trying to set up a repeat group and I am having issues with it reflecting. It is a group of users and when I wam selelcting the data source it shows the user I am running it as and not the list even though I have selected the current cells user, what could I be doing wrong?
Please pick a subcategory to help organize the information. Thanks!
Also, the more context you provide with your questions (screenshots, link to an open app, etc.), the more likely you’ll get good help quickly :slight_smile:
Can you record a screencast and share more about your RG settings? Also, did you check privacy rules?
The rules at this point are view all fields on both users own data and everyone else since I am just testing. I do not know though what RG settings are please tell me then I can record the video.
Hi Andilewilliams!
Base on my understanding… Have you tried debugging it? Inspect the element that you wanted to show in the RG if there’s a value being displayed in the data source.
Kindly see the screenshot below as a reference.
I am unable to add the recorded video here and this is what I was able to see upon debugging the element. Am I doing the debugging correctly as the information that I see on my side is not the same as the information that I see on your screen shot.
@andilewilliams
Please check your Privacy Rules in the Data tab of user data type.
This issue is most likely happening because the privacy rules for the User data type are restricting access — allowing you to see only the current logged-in user instead of the full list of users.
To fix this, review or adjust your privacy settings so that the repeating group can display all users as intended.
Thank you so much I had not sellected view this in search which was the cause.:flushed_face:
