Number Formatting Problem
Hello beautiful Bubblers!
A small problem with my progress bar :cry:
I want to set the Percentage = Current User’s M1L1 divided by 3
(M1L1 is a variable that takes value 0 or 1 depending on if a student has completed module 1 lesson 1)
But it doesn’t recognised M1L1 as a number even when I select “formatted as a number”:
Any ideas how to fix?
PS: I’m currently filming the “Build An App in 30 Days” documentary with Bubble so let me know if you’d like to be featured :slight_smile:
Best,
Andrew
Here’s how M1L1 is configured FYI:
Hi there, @andrewmitson94… if I understand your setup correctly, I think you need to reference the Current User's M1L1's Value.
Hope this helps.
Best…
Mike
Hey Mike,
I tried that but it doesn’t come up:
Any ideas why I can’t choose value here?
Best,
Andrew
So, M1L1 is its own data type, and it’s also a field in the User data type, right? What is field type of that field in the User data type?
Number I believe:
With M1L1 being a number, the Percentage field for the progress bar should take Current User's M1L1 / 3. The division operator is right there in your last screenshot. Select that operator and enter 3 after it.
The above being said, it’s a bit odd to me that M1L1 is both a custom data type and a field in the User data type. Is the field in the User data type supposed to be linked to a record in the custom data type?
BOOOM! Yes Mike, it’s workinggg :laughing:
Err not sure I understand what you mean but: every user has an M1L1, when they complete Module 1 Lesson 1 it should go from value 0 to 1. That’s all.
If there’s a way to simplify things would love to know :slight_smile:
