Hello Bubbler’s ,
I’m currently testing both your Free OCR Service and PDF.co plugins on Bubble.
Everything seems properly configured (API key active, URL reachable, workflow triggered), but the plugins are not returning any text from uploaded PDFs.
Here’s a summary of the setup and issue:
Environment:
Bubble app using “FileUploader A” element
Action: Free OCR Service – Extract Text
Input:
FileUploader A's value's URL -
API key: working and verified on OCR.space / PDF.co dashboard
Response fields: “Extracted text” returns empty (no error message)
Tested file:
https://c44ab259a394dd5e5921439bf776e52d.cdn.bubble.io/f1762953512390x704419736461483500/Hande%20cv%202016_1.pdf -
Same issue with other simple text-based PDFs.
Expected behavior:
The plugin should return recognized text (ParsedText) inside “Extracted text” or “ParsedResults”.
What was tested:
Different Bubble fields (
Extracted text,:first item,formatted as text) -
Direct API initialization from plugin editor (same empty result)
API key and service verified as active on OCR.space directly.
Question:
Could you please check whether there’s a current issue with text extraction from direct Bubble file URLs, or if the plugin requires a specific file type, encoding, or header (e.g., Base64) for proper OCR processing?
Any guidance or updated plugin version would be very helpful.
Thank you very much for your support,
Best regards,
Angelo Bari
