Parent group - need help
I’m a newbie with bubble and I’m trying to build an app like Instagram with a feed with posts. I’m following this tutorial that uses a repeating group for the feed, and then in the repeating group will put an image, choose dynamic image and then choose “parent group thing”. However when I do the same thing, the parent group option doesn’t pop up. Anyone know why?
I’m guessing you have a layer like this.
  1. image
  2. group (no data type selected)
  3. repeating group (has a data type)
All you need to do is to select the parent and set its data source to its parent which will trigger you to set it to the proper data type. The image should then work.
